Home > General Chat > Anodising and dimensions
Did a search but it doesnt seem to be covered.
Does anodising alter the size of an aluminium object at all, even by the minutest amount?
It does add some thickness to the material. Usually 50% of the thickness of the anodising the other 50% penetrates into the material, its only microns though!
What are you looking at having anodised? Gearbox maybe? :)
Brake callipers. Im concerned about the bore size
Carl is the man to answer this, I'm sure it is very little though and the pistons are probably enough clear of the caliper bores to get away with it. If not a v light hone afterwards will sort it.
shellspeed
Member #: 9580
Surrey
Typical anodising thicknesses range from 5 to 50 microns depending on application. That is per side and about half of the thickness goes into the material. A bore coated with a 25 microns of anodising will have a 25 micron reduction in diameter
according to my anidisers industry standard would fall between 8-11 microns where fitted tollerances are critical, any thicker and the surface grows unevenly and with it such a problem paul is trying to avoid
but as above ,if needed extra protection they simply leave it in the bath for longer.
carl
Cheers Carl
basil
Member #: 9458
Hertfordshire
There is a 1000 microns in a mm in case any one was wondering
Disk full (/tmp/#sql_3a2_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
