Home > General Chat > Hole Filling
Gavin Wakely
Member #: 793
I need to reduce the depth of a blind hole ie: main cap stud hole. I was concidering Loctite chemical metal. Any other recomendations or is this a good choice as I've known it used on cylinder heads before.
Gavin
Grubscrew?
shellspeed
Member #: 9580
Surrey
Assuming the hole is threaded, what about cutting a piece of threaded stud to length and cutting a slot in the end. That way you can screw it in and out as required
shellspeed
Member #: 9580
Surrey
Or use a grub screw is Paul just said as I was typing
Chalkie
Member #: 9764
Northamptonshire.
use a grub screw :] I did it at college with my assessment bit drill hole to deep so in went a grub screw, teacher didn't know *happy*
JB Weld *happy*
