| Home > Help Needed / General Tech Chat > Alternator/Ignition Light Issues | |||||||
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
4th Mar, 2012 at 02:01:57pm
So I'v got a problem with my alternator or the wiring it connects to.
4th Mar, 2012 at 02:04:06pm
There's a brown/yellow wire that runs from the alternator to the plug for the clocks. Use a multimeter to check continuity. On 11th Feb, 2015 robert said:
4th Mar, 2012 at 02:09:23pm
I'm fairly sure there is continuity and its not the wire to the plugs because my voltmeter shows the car isn't charging when the car is running.
4th Mar, 2012 at 02:15:34pm
Is the alternator plug on your loom clean? Especially the terminals. On 11th Feb, 2015 robert said:
4th Mar, 2012 at 02:17:53pm
yes. its something i can check again though just in case |
4th Mar, 2012 at 02:21:05pm
the alternator grounds out the said wire when it is not charging,
Yes i moved to the darkside |
4th Mar, 2012 at 02:33:31pm
So if the light is on, it must be the alternator? Can it possibly be anything else? |
4th Mar, 2012 at 02:35:05pm
what im getting at is that can a break in the circuit somewhere not also be a problem - I take it the ignition light would not come on at all if there was a line break |
4th Mar, 2012 at 02:46:59pm
The ignition light gets 12v from the dash when you turn the ignition on On 11th Feb, 2015 robert said:
4th Mar, 2012 at 03:31:54pm
On 4th Mar, 2012 apbellamy said:
The ignition light gets 12v from the dash when you turn the ignition on and is earthed at the alternator when its not charging, if the light comes on at all, there is no problem with the wires assuming they go to the correct place and the bulb obviously works the issue is the alt not charging voltmeter across the battery will confirm this On 4th Mar, 2012 carts60 said:
I should say the alternator has also been checked on another mini to make sure its actually charging and a good unit. youve said this alternator worked fine in another mini if it does im 100% stumped and can only suggest trying the other minis alternator in your mini and if that doenst work either im 200% stumped :) Edited by Brett on 4th Mar, 2012. Yes i moved to the darkside |
