Page: |
Home > Beginners Tech > distributor drive position | |||||||
![]() 168 Posts Member #: 9709 Advanced Member Cirencester, glos |
6th Mar, 2012 at 08:07:37pm
I need to set up my ignition timing again as I don't think it is correct. I don't have any haynes manual so just sourcing information from the forum really.
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
6th Mar, 2012 at 09:09:22pm
I believe its 1342 |
6th Mar, 2012 at 09:11:55pm
The firing order is 1342 going anti clock wise.
6th Mar, 2012 at 09:14:08pm
sorry i did mean to put 1342, is the set up the same for the metro turbo electronic ignition as it is with points ignition??
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
6th Mar, 2012 at 09:25:41pm
On 6th Mar, 2012 Rickus said:
i cant seem to get my cat to run when set up to this cheers, Rick I don't think my cat would run to well with a dizzy poking out of her, no matter how I attached the leads! ![]() one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
6th Mar, 2012 at 09:32:45pm
brilliant that almost made me piss myself with laughter
6th Mar, 2012 at 10:07:53pm
Yeah its exactly the same, it just has a solid state relay (ignition module) instead of points.
7th Mar, 2012 at 05:54:19am
I have got a 12v supply running straight to the coil.
7th Mar, 2012 at 08:55:49am
But what about the dizzy?
7th Mar, 2012 at 11:27:57am
Yeah that's my dizzy I have the wire tht run to the distributer. Should the vacuum be on the top and electronic black box to the right?
7th Mar, 2012 at 11:39:05am
If you've got it wired corecctly and you have no spark and the point dizzy works, then it could well be a faulty ignition module.
7th Mar, 2012 at 05:41:29pm
I have a spark and it is popping today but still won't start.
7th Mar, 2012 at 05:50:00pm
If its popping then you could have it timed 180 degrees out, so its sparking when the exhaust valve is open. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Mar, 2012 at 07:20:55pm
That's was exactly it and its running really well now and I can actually move it wooooooooooop
7th Mar, 2012 at 08:41:34pm
It could be the ignition module again as they can play up under load, check your fuel pressure first though. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Mar, 2012 at 08:56:45pm
Oh right I see. I will check all my fuel again. Should the pipe going from the plenum to the regulator be 8mm? Would that make a difference? I am using 6mm at present. I changed the pipe from turbo cold side to actuator for a solid piece and got rid of the bleed valve for now.
7th Mar, 2012 at 08:59:04pm
This pic is on idle |
7th Mar, 2012 at 09:15:07pm
Yeah reading vaccum is fine for where you have the signal hose fitted.
7th Mar, 2012 at 09:18:20pm
Thank you again I will do some more investigation this weekend.
7th Mar, 2012 at 09:24:28pm
Im not sure how to test it tbh for an intermittant fault, the only way ive done it in the past is to swap it out and see if it makes a difference.
9th Mar, 2012 at 09:20:18pm
For boost I think I might try the t piece mod to make sure my carb is working properly
11th Mar, 2012 at 10:28:25pm
Everything now is working as it should thanks for all the help and advice
11th Mar, 2012 at 10:32:06pm
what did you have to do in the end? one day boost will be mine!
12th Mar, 2012 at 05:03:40pm
I replaced the coil ht leads and plugs and also done the t piece mod to pressureize the float. Chamber.
![]() 4630 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
12th Mar, 2012 at 05:55:40pm
Yes, if you need to. Mines had the T-piece fitted for years. |
Page: |
