| Home > Help Needed / General Tech Chat > Minispares 4 pot calipers disc options | |||||||
8th Mar, 2012 at 07:59:44pm
8th Mar, 2012 at 08:08:10pm
i think its fine to use turned down disks, i think paul wiginton and nick use turned down disks. I can't say for sure though, have a search and it may turn up the answer. |
8th Mar, 2012 at 08:32:03pm
I use those very calipers. I used the std 8.4" hubs but fitted the supplied drilled discs. They are s discs I used - wether the turned down 8.4 would work on 7.5's i dont think so. Someone might correct me but I thought it was just the 7.9's that used turned down 8.4's?
8th Mar, 2012 at 08:46:45pm
8th Mar, 2012 at 09:08:33pm
I use MS callipers on turned down disks I seriously doubt it! |
8th Mar, 2012 at 10:22:35pm
i use 8.4 pagid 40 groove turned down, best brakes i have ever had Crystal Sound Audio said:
8th Mar, 2012 at 10:36:38pm
Excellent, I shall find a lathe.
8th Mar, 2012 at 10:44:12pm
turn them in the lathe as slow as possible, sub 80 rpm On 28th Aug, 2011 Kean said:
8th Mar, 2012 at 10:46:33pm
8th Mar, 2012 at 11:28:24pm
You'll need spacers to run S disks. Turned down 8.4s are what you need.
In the 13's at last!.. Just |
1083 Posts Member #: 8932 Post Whore |
9th Mar, 2012 at 12:40:29am
What is the reasoning for using such a slow rpm out of interest joe? |
9th Mar, 2012 at 10:34:52am
Why spacers? I run these without spacers, and have not had any issues, unless I don't have s discs... But they are the non vented 7.5". I'm now confused... On 7th Nov, 2011 apbellamy said:
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
9th Mar, 2012 at 10:49:50am
I have mini spares callipers with 7.5 solid disk and have spaces fitted, don't need spaces with vented discs I presume.. Main Build
9th Mar, 2012 at 11:25:52am
the spacers are to mount the caliper out from the mounting flange there just big washers really S disks sit futher out than 8.4's, there is also a spacer for running vented disks that goes between the two halves of the caliper dont be confused by this Crystal Sound Audio said:
9th Mar, 2012 at 02:51:58pm
Point noted, when you stoody what you have said mate It is as plain as you're nose on you're face..
Edited by nala56 on 9th Mar, 2012. Main Build
