| Home > General Chat > help with Carb Identification please | |||||||
11th Mar, 2012 at 03:07:01pm
I found a carb in the scrapies I think its a HIF38 but can anyone tell me?
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
11th Mar, 2012 at 03:25:22pm
It's either a 38 or a 44, just measure the diameter of the bore to find out which. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
11th Mar, 2012 at 03:29:54pm
Oh right okay will it fit a mini and work fine? |
11th Mar, 2012 at 03:39:54pm
Yeah, either a 38 or 44. Depends what engine, i wouldn't fit a 44 on a 998 unless its of a high tune. 38 will do on a standard 1275, but no good on a tuned one again.
11th Mar, 2012 at 03:46:09pm
Ill go measure it now :) and No idea what engine im running yet :(! not been to see a familyt firend she has a few laying around |
11th Mar, 2012 at 03:51:14pm
Its a 44 :) thanks guys is it missing anything though the? it looks like it had something bolted the other side of it
11th Mar, 2012 at 04:10:01pm
11th Mar, 2012 at 04:12:21pm
11th Mar, 2012 at 04:13:10pm
On 11th Mar, 2012 apbellamy said:
one half of a pair from a rover v8 Very persific :) fine to use on a mini though? |
11th Mar, 2012 at 04:17:03pm
yes as long as you put the right needle in it On 11th Feb, 2015 robert said:
11th Mar, 2012 at 04:18:55pm
Thought these could have been off a rover v8 but wasnt sure. Chap I know has some on the 3.5 in his lightweight. He had cone filters on his though. A lot of people turn to webers as the 44 Isn't good enough supposedly. If it can supply enough air for 1.75l of engine, It's more than capable enough of anything in my opinion! Edited by Carlzilla on 11th Mar, 2012. On 26th Jan, 2012 Tom Fenton said:
432 Posts Member #: 7856 Senior Member Essex |
11th Mar, 2012 at 04:19:08pm
It would work, you'll have to set something up for the choke though
11th Mar, 2012 at 04:22:48pm
11th Mar, 2012 at 04:32:45pm
On 11th Mar, 2012 Amp said:
It would work, you'll have to set something up for the choke though There is a tag on it, if you type that code in you can see what it is off, I think that's on Burlen's website There is a tag on it what i was surpirsed at normally they have been broken off :( and what is the site address please? |
11th Mar, 2012 at 04:33:40pm
the trumpet was a dead give away Its the trumpet i seen first on a big pile of scrap alloy i was like Grab it! haha :) i checked all around and found a Mini diff but it was broken :( |
11th Mar, 2012 at 05:16:04pm
I believe it is:
11th Mar, 2012 at 05:28:33pm
11th Mar, 2012 at 05:30:52pm
I don't believe that search page! Apparantly a 1968 Wolseley Hornet 998cc has TWO carbs.... On 26th Jan, 2012 Tom Fenton said:
11th Mar, 2012 at 05:41:58pm
Thats because it is a search page, you type in the FZX number and it tells you the history!
Edited by Amp on 11th Mar, 2012. |
11th Mar, 2012 at 05:44:39pm
honet had the cooper 998 engine isnt it? On 28th Aug, 2011 Kean said:
11th Mar, 2012 at 05:52:33pm
It would work, you'll have to set something up for the choke though The choke is just below the throttle, you'd just need to find the range rover abutment plate. On 11th Feb, 2015 robert said:
11th Mar, 2012 at 06:04:17pm
Not sure Joe, ours has a single HS2, an airbox with a cooper service sticker on, and we can't figure out the numbers on the head. It's remote change too. On 26th Jan, 2012 Tom Fenton said:
11th Mar, 2012 at 06:08:46pm
It would work, you'll have to set something up for the choke though The choke is just below the throttle, you'd just need to find the range rover abutment plate. Or, fit a mini one, but you will most likely have to drill and tap two holes into the body of the carb to hold the choke mechanism in place. |
11th Mar, 2012 at 06:37:19pm
It would work, you'll have to set something up for the choke though The choke is just below the throttle, you'd just need to find the range rover abutment plate. Or, fit a mini one, but you will most likely have to drill and tap two holes into the body of the carb to hold the choke mechanism in place. What are you on about? Throttle at the top and choke at the bottom!
11th Mar, 2012 at 06:45:39pm
I thought that....
