Home > Help Needed / General Tech Chat > avonbar alloy actuator Q
mettyturbo
Member #: 344
The Royal Mail lose every parcel I ever send.....and I am a TWAT
if i buy an avonbar 12psi actuator do i have to run 12 or could i run 10psi cheers lee
you will run 12psi
if you buy a 10 psi one you will run 10
and so on .......................
better to go with the lower number and then you can bleed the signall off to the actuator later on
giving you a higher boost figure
but thats another story.
watch boost figures over 8 psi on a standard turbo motor with standard C/R ratio as this can cause detanation and rapidly blow the head gasket or at worst melt the pistons .....
mettyturbo
Member #: 344
i have got low comp pistons is it safe to run 12
if you by a 12 psi act, you could run it at 4 psi if you like. it doesn't have to be at 12!
you could prob run it at 14 or more if you needed, so yes it's only a guide fig as it depends on how you set it up!
Edited by Miniwilliams on 5th May, 2005.
mettyturbo
Member #: 344
well i was hoping to run 10 ive been told that you can adjust it by screwing the rod in or out is this true
personally i would just get an 8psi one and use your bleed valve to raise it up to 12psi when you want the power
yes like i said you can almost run what you like sort of, so yes that's how you ajust it.
i think the way to go mat is say 8 psi actuator and then you may get enough preload by adjusting the rod lenth to 10 ish.... if you wish
this helps to eliminate boost creep.
then bleading the signal off to raise the boost further.
going the way say from a high sprung actuator say 12 down would induce boost creep further on the actuator which helps to rob the motor of all the driving fun
having said that! thats only my oppinion *indifferent*
Edited by BENROSS on 6th May, 2005.
I adopt Ben's strategy - use slightly less pre-load. Lets be honest, are you ever going to de-tune your car? Unlikely! So a 12psi unit with a smaller pre-load will do the job just fine, and have bags over for future boost increases.
turbo hogster
Member #: 178
stowmaket suffolk
like the pic dave.
fair enough ben:) good point.
i just thought that the least you bleed off the better.
