| Home > Help Needed / General Tech Chat > Front Subframe Tie Bars | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
15th Mar, 2012 at 09:25:07pm
Hi again, I'm running a fg flip front and am going to continue the rollcage tubing from where it meets the front bulkhead/top subby mounts down to the front of the subby to stiffen it all up.
www.topcatcustom.co.uk |
15th Mar, 2012 at 10:16:09pm
I think there is a bit more engineering goes into crumple zones than just adding a random weak spot. I'd forget the idea. |
16th Mar, 2012 at 08:18:48am
Surely theres a bit more engineering goes into car body design than just putting a massive roll cage in the design!
16th Mar, 2012 at 08:53:32am
Personally I think it is a very good idea to do what you can in the design if you have the opportunity - although I don't have a cage, I certainly took the loading into account when I made my brace bar.
Edited by Rod S on 16th Mar, 2012. Schrödinger's cat - so which one am I ??? |
