Home > General Chat > silicone hose for oil drain?
bennyy
Member #: 9037
Doncaster, yorkshire
What hose have you used as some aren't suitable for fuel or oil? The fluorosilicone lined fuel and oil hoses I have seen on the likes of demon tweeks say not suitable for perminent fuel or oil? I'm after a 90 bend if possible.
Edited by bennyy on 17th Mar, 2012.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Silicon will be fine.
We used silicon on the skip and the only bits to leak was my shocking fabrication...
bennyy
Member #: 9037
Great stuff, Andy that's why I'm going for a 90 bend, one less weld to leak lol
Try using silver solder rather than welding it. Works lovely. No leaks.
bennyy
Member #: 9037
Too late its all welded up and doesn't leak, just cannot be bothered to weld a 90 on to be honest.
Oil will eventually seep through the silicon rubber hose and will always be wet on the outside. It'll still work if you are happy with the hose always being oily
The fluoro silicon hose is what you really need. The fluoro hose is resistant to oil and deisel, and limited petrol vapours
Paulham
Member #: 9654
NW London
What inner diameter tube should be used?
standard metro one is 3/4" or 19mm
bennyy
Member #: 9037
Mine is about 15mm iirc, I would go for the fluoro lined but it only seems to be available in straight sections.
has any one any links for the fluoro hose 90 bend ?
bennyy
Member #: 9037
I'm not sure it exists Steve, I cannot find any anywhere
You're not trying very hard Benny...
http://www.ebay.co.uk/sch/i.html?_nkw=90+s...6.c0.m270.l1313
hazpalmer
Member #: 9038
Carlisle, Cumbria
ebay seems to always turn up top trumps
bennyy
Member #: 9037
Andy you are an eBay genius
to be fair ebay is shit on a phone isnt it bennyy *happy*
I searched for '90 silicon oil', not exactly rocket science....
bennyy
Member #: 9037
I searched for everything exept that
JT
Member #: 637
Hertfordshire
or
fluoro silicon hose
that worked!!
just ordered the 45 degree one
My build thread..
Disk full (/tmp/#sql_3a2_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
