| Home > Help Needed / General Tech Chat > Ignition advance with high boost | |||||||
18th Mar, 2012 at 08:02:06am
After reading about a potential issue following a rolling road tune, I thought id ask this as I am going to SRE this Friday - I trust that Neil will do a very good intelligent tune.
18th Mar, 2012 at 08:07:04am
With that CR and cam I'd say running 24 deg advance on boost will be safe. Not sure what boost you are looking at but 15psi will be fine.
18th Mar, 2012 at 08:12:41am
We stuck 25psi+ into the van's engine on 8:1. It took it all day long. Gasket, bores and pistons where perfect when we took it apart. On 11th Feb, 2015 robert said:
18th Mar, 2012 at 08:20:25am
Yes wil, gt17.
18th Mar, 2012 at 08:22:39am
The 173 was achieved on 17psi. Fuck knows what it was doing on 25psi apart ruining my underwear on the way to MITP. If something is worth doing, it's worth doing half of. |
18th Mar, 2012 at 08:26:13am
25 psi is a bit scary on the road, but good fun on the strip... On 11th Feb, 2015 robert said:
18th Mar, 2012 at 08:31:09am
Hahaha!! Well it's interesting at 10psi - rather a lot of torque steer, can't imagine what 25 would be like! Fun though I'm guessing!
18th Mar, 2012 at 08:43:13am
We had a valve on the bleed line. Wheel mounted switch flicked between 7psi and 25... We needed that to get it of the line without masses of wheel spin. On 11th Feb, 2015 robert said:
18th Mar, 2012 at 08:50:49am
With it set up well on 8:1 20-22psi is fine, iirc nick on here runs around that boost on 8.7:1 Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
18th Mar, 2012 at 08:53:34am
Yep. My next engine will be higher compression. Something around the 8.7:1 marker. If something is worth doing, it's worth doing half of. |
18th Mar, 2012 at 09:04:48am
I plan to run 20odd psi on 8.31:1 Audi s4 b5 - 470bhp & 486ft lbs
18th Mar, 2012 at 09:16:08am
Yeah i'm running 20psi on 8.7:1, my advance is 22 degree's across every slot when on boost. I did bump it up and down a bit when on the rollers before but it didn't make any difference so have just left it as is. On 20th Oct, 2015 Tom Fenton said:
18th Mar, 2012 at 12:35:21pm
I'm on 8.6:1 , 20psi, 18 deg.
In the 13's at last!.. Just |
18th Mar, 2012 at 01:08:45pm
Ive been running asmuch as 23+psi on 8.3cr and 18 deg advance Yes i moved to the darkside |
