Home > Help Needed / General Tech Chat > lean on 1 & 2?
almichie
Member #: 2065
Im prepping the car for its first rolling road.
I pulled the plugs tonight to check.the tapets and found plugs in one and two near white and three and four blackish.
I carried out a comp test all showing 155 more or less cold. Any ideas?
It seems to run ok, im a bit worried something might melt if it is lean? Afr shows 11/12 at idle
Shaft seems nice and snug
intake air leak at manifold?
almichie
Member #: 2065
Funny you should say that - i had a misfire, i found a loost nut on the inlet - tightened it went away. So i have probably damaged the gasket?
I have a new one but didnt fit when the misfire wenr. Bugger.
almichie
Member #: 2065
Can the inlet be resealed? Ie with a smear of instant gasket? Or should i fit a new gasker? Im not sure i have the time to fit a new gasket...
tadge44
Member #: 2500
Buckinghamshire
New gasket definitely. Go without sleep if you have to.
almichie
Member #: 2065
Ah well.... I'll be up all night tonight then!!!
