Home > Wanted > 998 High flow Oil Pump, 3.2/3.1/2.9 CWP, X-Pin diff
Mike-998
Member #: 9774
Buckinghamshire
After said parts, Ideally a Minispares diff, but not too fussed, and need a slot drive pump.
Mike
Edited by Mike-998 on 21st Mar, 2012.
david_godfrey
Member #: 9860
Ive gor 3.1 and 2.9 and maybe 3.2 CMP's which one would you prefare and what price are you willing to pay?
Thanks
dev 11
Member #: 9393
stoke on trent
I'm after a 3.1 mate
I get a metro turbo pump, took it to bits and ground down the drive peg to the same size as a 998 one (All done with a 4.5" angle grinder, no need for accuracy, it's a sloppy fit as standard).
Then I drilled and tapped a new hole to bolt the pump on (one hole alreay lines up.
Simples. No point buying a second hand pump.
Mike-998
Member #: 9774
Buckinghamshire
I've actually been looking at morspeed's 998 high flow fuel pump, which, for £25 seems the best option at the moment.
Has anyone used these before?
I thought morspeed had gone to the wall?
Mike-998
Member #: 9774
Buckinghamshire
Ahh, that might be the reason I havnt had a reply from them yet...
How is that website still online?
As above you'd be better off spending all your money on magic textbooks and trying to cast a high capacity spell on your current oil pump, then buying one from Morspeed.
Mike-998
Member #: 9774
Buckinghamshire
I have actually just got a reply from morspeed, so I'd imagine they're still going?
And the only problem with doing that is that I have next to no tools available to me and no workshop to work in either. As I also need to order some new bearing and maybe a crankshaft, I might as well get the pump from them at the same time.
You've been warned.
Have a look at some other members' experiences.
Mike-998
Member #: 9774
Buckinghamshire
When you say past experiences, do you mean with morspeed's oil pump? Or modifying a metro one?
Thanks for the advice though, I'll start looking around for metro pumps then
Do a search for Morspeed.
Alex
Member #: 1851
Woolavington, Zummerzet
I have a couple of complete 3.1 diffs kicking about if this thread hasn't wandered too far off track.
Mike-998
Member #: 9774
Buckinghamshire
Alex, how much would you be after (inc postage) for them?
dev 11
Member #: 9393
stoke on trent
Same!
