Home > Help Needed / General Tech Chat > Cylinder head/valve help
jlay
Member #: 1742
essex
Hiya i am collecting parts for my project and am planning on using a 12g940 head to turbo. I know that the original turbo head had sodium filled exhaust valves but i think the inlets were standard. the head im going to use has standard inlets and exhaust do you guys recommend i change the exhaust valves for some decent EN214n spec valves (or similar) or should i change the lot. Thanks for your time james
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
These sodium filled valves are not needed, you would be better off getting a fully modded head with combusion chambers reshaped with 26 to 28 ccs in there to lower the compression ratio, so you can run alot more boost,
race valves, double springs and 3 angled seats, and satellite hardened exhausted inserts, for unleaded fuel especillay if its for the road.... but it depends on your budget..... and what you want from the engine..etc
Hope this helps.
jlay
Member #: 1742
essex
Cheers for the reply. Im on a tight budget (as always lol) and i do like to port my own heads. i will be opening it up as required de shroud the valves a little and wast back around the inlet guide but just flow around the exhaust guide for heat transfer. will i get away with just changing the exhaust valves to a higher grade or will the inlets suffer too. Cheers james
Standard road spec inlets will be fine. I'd stick the stainless exhausts running in bronze guides in there for good measure though.
What the hell are "satellite hardened exhausted inserts" Steve ? lol
Edited by Turbo Phil on 23rd Mar, 2012.
tadge44
Member #: 2500
Buckinghamshire
He means Stellite I think.
I know ! Lol
Mr Joshua
Member #: 1954
Luton Bedfordshire
If you can find a MG Metro head and change the exhaust valves only. Your only smudge of a mill smaller for max safe valve size if memory serves. If your on a budget it's worth thinking about.
Own the day
Phillips don't be silly its this bloddy predictive textttttttt. ...........lmaoooooo
