Home > Help Needed / General Tech Chat > Engine running in help
Grahamxx
Member #: 8588
Yeovil
I'm just rebuilding my engine, how do you guys run your engines in? there seems to be so many different ways of bedding the rings in. What running in oil are you using?
Thanks in advance..
Graham
Graham
cheap oil, 2k for 15 mins, ,change oil , then same again, change oil,the a couple of hours at 2-3k,
mineral oil, 2k rpm for 15-20 minis to knock the cam in then 8 trips up the pod for me *happy*
Craigie-B
Member #: 9468
Wootton Bassett
a couple of hours? Do you not do it for 500 miles? Im comming up to the running in stage myself and so would like to know *tongue*
bennyy
Member #: 9037
Doncaster, yorkshire
Let it idle at 2k rpm to bed in the cam and followers, take it to a nice back lane, 3rd gear slots of aceleration and letting it decelerate, eg cruise at 2k rpm, accelerate lightly upto 4k then back to 2 etc etc for drive like this for 59mile or so
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Mr Joshua
Member #: 1954
Luton Bedfordshire
I am using coma 20/50 and only 7 psi off boost for 500 miles beating in mind my cr worked out insanely low.
Own the day
almichie
Member #: 2065
I did 20 minutes at 2k rpm, out on the road lots of low rpm load. Did that for 15 minutes then upto 4k at 7psi drive like normal for 300 miles then boost to 10psi and rolling road.
I see 155psi across all 4 cylinders and NO oil use.
Shaft seems nice and snug
Knock in the cam then fookin nail it
pot_dan
Member #: 326
bradford, west yorks
Bet your naighbours love that carl!
