Home > Help Needed / General Tech Chat > Metro Turbo Carb Problems
Jon731
Member #: 9848
Bournemouth
Standard metro turbo conversion project.
So over the weekend i have made some progress, installed my X pin diff changed the cam, rebuilt and dropped into the car.
i was nearing the stage of first start so i was testing the fuel system to make sure all was ok, however when it pressurized i noticed the float chamber under the carb began to leak, this carb was taken straight from a metro turbo so am confused to why this is happening.....
I plan on just rebuilding it, as presume the rubber seal is faulty(how do you get those strange screws off the bottom?), i just thought there might be some obvious thing that someone on here knows as a potential cause....
Many Thanks,
Jon
wez
Member #: 9271
Stoke on Trent
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2878
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Jon731
Member #: 9848
Bournemouth
Thanks that will be useful guess its just a poor seal then
Mr Joshua
Member #: 1954
Luton Bedfordshire
Am going to ask a simple and on the face of it stupid question. You have fitted the fuel pressure regulator and set it to 3-5 psi? Silly I know.
Own the day
Jon731
Member #: 9848
Bournemouth
Well... i haven't actually checked but i took it straight from my brothers car, which was running so presume its ok.
