Home > Help Needed / General Tech Chat > boss welding
wng691s clubby
Member #: 9252
Cleethorpes
hi guys not been on for a rw weeks as iv been moving house but its all sorted now and back on with the turbo build so i orderd my a/f ratio gauge today and wondered if anyone wouldnt mind welding the sensor boss for me as im guessing it has to be totaly sealed. and my welding isnt perfect.
Done now needs redoing lol
if you have a welder mate just have a bash, throughly clean the area and give it a couple passes
wng691s clubby
Member #: 9252
Cleethorpes
i thought it may have to be sealed really well that was all and i know some of you guys have tig welders which would be better for the job, but if it doesnt really matter then i shall, am i correct in thincking best place for sensor is before the knuckle in the exhaust?
jlay
Member #: 1742
essex
i mig or tig my ones depends on material and if second hand exhaust im welding to.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
I mig'ed mine
benspickup
Member #: 9608
Lincolnshire
Hi mate, if you drop it round to mine- I live in horn castle which is down the road, il weld it up for you at work! Fabricator by trade you see! If you do it yourself just get it good and clean and protect the threads from spatter. Cheers Ben
Oh yeah make sure you fit a bung in place when welding, otherwise it will more likely distort.
bennyy
Member #: 9037
Doncaster, yorkshire
You ll be suprised how much you can get away with, many exhaust firms are not air tight
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Yes before the knuckle joint
Main Build
Upgrade to Turbo
the carbon build up nicely seals minor imperfections *happy*
nala56
Member #: 9661
This is where I put my boss, when its on the car it faces the opening in the subframe just right to bring the wire through, make sure you angle it up slightly..
Main Build
Upgrade to Turbo
