Home > For Sale > modded ford cosworth 2wd intercooler and hoses
bennyy
Member #: 9037
Doncaster, yorkshire
I am selling my intercooler as I will be getting a custom one made up for behind the grill. It's a ford cosworth 2wd intercooler, with the end tank turned 90degrees, the take off cut down and a bead of weld around the edge, all welded by TM's own, Tom Fenton, it took a fair bit of tweaking to get it to fit under a roundnose, it took two trips to toms and 2 hose reducers as I cut both down too short the first time around. So I am including the pipework for the turbo side, and the reducer for the other side.
So you get:
Modded cossie intercooler
1x 90deg. 63-51mm reducer (plenum side)
Turbo side:
1x 45deg 63-51mm reducer.
1x 51mm stainless 45deg. Bend
1x 90deg 52mm hose
I am asking £60ono + £12 postage.
Can be collected also.
Here's some pics fitted.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
would this set up work with the bonnet fully closed? (It looks like you've got the pins set up for the raised bonnet)
bennyy
Member #: 9037
The back of the bonnet sits about an inch at the rear, I'm not sure as its always been lifted. With a smaller altenator it would definately fit.
welshdan
Member #: 1111
s wales
good deal that. i run the same setup on my car. if you cut and weld the strengtheners to the underside of the bonet to clear the pipework it can be made to fit with the bonnet fully closed. as seen in my build thread. dan
pm'd
bennyy
Member #: 9037
Oh yes that reminds me Rob, it won't fit with the bracing on the underside of the steel bonnets.
welshdan
Member #: 1111
s wales
we cut mine out and rewelded shallower bracing sections in. i also ground a flat top to one of the alternator lugs to get the ic to slit as low down as possible. it will fit quite neatly but is tight! if you need pics let me know, cheers, dan
Thats cheap tbh i have a similar setup un modified it did just scrape under the std bonnet but ive changed mine slightly since then
bennyy
Member #: 9037
Brett it has cost me a lot more, but shit happens lol This is provisionally sold by the way.
bennyy
Member #: 9037
Now sold, cheers Rob
