Home > Help Needed / General Tech Chat > Clutch Plunger
jamie@thefatgarage
Member #: 9345
Sheffield
Can someone tell me what the purpose of the throwout nut (22A427) and locknut is on the end of the clutch plunger on a verto setup? The locknut on mine has come off and the flanged nut was on it's last turn of thread, but everything works fine...
i have no idea but i can tell you i put the 2 nuts on the plunger locked em together and not touched em since,
jamie@thefatgarage
Member #: 9345
Sheffield
Yes, that's what I did. Except I clearly didn't tighten them up enough!
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Its a type of limiter to stop the clutch from to much travel, the way to set it up is to put your clutch peddle to the floor keep your foot pressed down then take up the slack with the big nut let your foot off the peddle turn the large nut one flat in, then do up the lock nut to keep that setting, Its best to get some one to press the peddle down whilst you do the adjustment..
Main Build
Upgrade to Turbo
Kean
Member #: 341
aka T2clubby
South Staffs
As above, it limits the travel, and hence stops any excessive end load on the crank and thrusts.
I'd get one back on sharpish as you may be putting extra load on your thrust bearings.
jamie@thefatgarage
Member #: 9345
Sheffield
Looks like I'm buying another lock nut then.. cheers for the info.
it is a safeguard there to stop you pumping/jacking the clutch out to far too far, if your return spring is fitted and everythnig is free it should never overthrow once setup correctly,
i don't have them on the Don or twinnie
crap, were dealing with verto not pre verto!
Edited by minimole23 on 30th Mar, 2012.
nala56
Member #: 9661
If its Verto there is no return spring..
Main Build
Upgrade to Turbo
I've got a few throwing round if you are passing Jamie.
jamie@thefatgarage
Member #: 9345
Sheffield
Cheers Andy, I might pop round tomorrow depending what time I finish messing with the car. I'll call you.
nala56
Member #: 9661
If Andy hasn't got one I have, just PM me if you need one..
Main Build
Upgrade to Turbo
Will be in the garage most of the day.
