| Home > General Chat > O/T Looking for new daily drive: V50 1.6D = problem car? | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
31st Mar, 2012 at 06:21:57am
I could do with some advice;
Dazed and Confused.... |
31st Mar, 2012 at 09:11:09am
we have the ford/french 2.0 dci engine thats fitted to the focus, dmf's in general last approx 100k on average imo from most manufacturers, if you do have to do the dmf then use LUK parts and do the slave cylinder when the gearbox is off
31st Mar, 2012 at 11:27:58am
Cheers Wolfie, much appreciated.
Edited by Yo-Han on 31st Mar, 2012. Dazed and Confused.... |
31st Mar, 2012 at 12:03:13pm
On 31st Mar, 2012 Yo-Han said:
Any way to detect a DMF or turbo failure is coming on soon (apart from performance loss)? From my experience with the infamous Ford (2l Mondeo TDCi) DMF you get a distinctive rattle at idle as the two halves hit the limit stops. You also have the starter jam regularly from the metal swarf produced by the two halves rubbing against each other but of course the starter may have been replaced to hide the underlying DMF failure (a starter motor change is cheap, a DMF change is not....). The death rattle will allways go once the revs rise (as the two halves no longer have to move relative to each other) but the Mondeo engine has another endemic design fault - Aux belt tensioner - which sounds very similar..... The turbo on my Mondeo (GT1749VNT) just failed with no warning - shaft broke in two...... running fine then no boost and a cloud of blue smoke.... For what it's worth, EuroCarParts told me (when buying my new DMF) that the Ford one is their best seller and the VW/Audi 2l, their second best - they didn't mention the VW/Audi 1.6 Schrödinger's cat - so which one am I ??? |
31st Mar, 2012 at 12:56:14pm
rattle on idle (sounds a bit like release bearing rattle) and irregular idle
31st Mar, 2012 at 02:45:59pm
Cheers men, I will pay special attention to rattle on idle.
