Home > For Sale > Gauges, widget, master cyl, speedo cable
jamie@thefatgarage
Member #: 9345
Sheffield
All prices inc delivery, I've guessed at what they are worth so if I'm miles out make me an offer.
14mm straight through adapter with 1/8npt hole for temp sender. £7
52mm Gauges RPM 0-8000 £15, Coolant temp £10, Boost (psi 0-30) £10 or £30 the lot (they are all secondhand and may need a polish up)
This is the model http://rspec.co.uk/performance-gauges/smok...er-white-series
Tin clutch master cyl + rebuild kit £25
New speedo cable (centre clock one..) £5
adrian
Member #: 2726
wakefield
How much for the lot mate? I'm just up road in wakey so can collect.
Adrian
jamie@thefatgarage
Member #: 9345
Sheffield
£50?
adrian
Member #: 2726
wakefield
Ok mate. Deal. I'm off work Tuesday n wednesday so can collect before 5 on thm days?
jamie@thefatgarage
Member #: 9345
Sheffield
PM'ed
jameswildcooper
Member #: 1355
Leicester
if sale falls through ill take boost gauge and master cylinder
Amp
Member #: 7856
As above, if it falls thorough i'd be interested in the straight through adaptor
maccamcvey
Member #: 6673
Worral Sheffield
adaptor and speedo cable for me, on the seconds that is.
James
