Home > General Chat > Mondeo TPS wiring
Guys ive got a mondeo tps and wondered if anyone knew the wiring order off hand?
Ta
Mike
Like this
Edited by MikeRace on 1st Apr, 2012.
Amp
Member #: 7856
If your willing, message me your registration and I'll look at the wiring diagram for you?
you can measure it mike and work it out if you have a multimeter
i would guess the outside 2 will be +5v/0v and the centre one will be the signal depends whether you want the output to scale up or down as the throttle is applied ( usually up i think) in which case you want to measure the ohms between the centre pin and the the outer pins the lowest value would indicate the +5v pin
Edited by Brett on 1st Apr, 2012.
Ill give this a whirl brett, what setting do i use on the multi?
something for resistance, i cant remember what total resistance mine was
Mike, its easy to test and work it out, bring it over if you get stuck.
Just dug up some othet threads on this tom. Thanks for the offer bud. I think ill get on ok :)
evolotion
Member #: 83
Glasgow, Scotland
evolotion said:
get a multimeter, set it to resistance, say the 20k range.
now you have 3 connections, so you have 3 possible pairs of connections (polarity is irrelevant) measure them whilst swinging the tps from the "throttle closed" position to the throttle open position.
one pair will stay constant,
one pair will increase in resistance
one pair will decrease in resistance.
noting the 2 pins that stayed constant, the other pin is the TPS's output!
now noting the 2 pins that started at a low resistance and moved to a high resistance as the throttle opens, one of these pins will also be one of the pins whose resistance stayed constant. this is the 0v input.
now noting the 2 pins that started at a high resistance and moved to a low resistance as the throttle opens, one of these pins will also be one of the pins whose resistance stayed constant. this is the 5v input.
HTH buddy
Denis O'Brien.
ZootecS
Member #: 9988
Did you ever work this out mate..?
Im putting the same tps on my Omex but don't have a sensor connected to a power source so cant use a multimeter! :(
hazpalmer
Member #: 9038
Carlisle, Cumbria
when you do resistance checks, you need to isolate what your testing and make sure power is off.
ZootecS
Member #: 9988
I literally have a sensor plug in my hand with 3 wires connected to it.. and i have a sensor that is connected to a set of ITB's in my bedroom *tongue*
It's an ongoing project that i am now building an Omex loom for, hence the strange situation! haa
Cheers for the reply :)
you dont need power to do a resistance test,
