| Home > General Chat > Fitting FG front end | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
1st Apr, 2012 at 08:10:50pm
Hi, fitting a 2 pc fibreglass front end from ABS with the built in A panels, is there a general way of lining it all up (height wise) so that the nose points at the right angle?! The sides are oversized so made to be trimmed to the doors, hence why I need to know how to line it up before trimming to fit.
www.topcatcustom.co.uk |
![]() 1014 Posts Member #: 238 Post Whore essex |
8th Apr, 2012 at 05:35:52pm
They are a bit of a bugger to fit, im in progress of fitting my one, i've got a clubman one that has A panels but i want to cut them off, as my A panels are new. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
8th Apr, 2012 at 05:45:04pm
There is no easy way to fit a FG front. It is just mount it rough stand back and have a look, repeat this until you are happy with it. At least that is how I have always done it. http://www.twin-turbo.co.uk
8th Apr, 2012 at 07:22:28pm
I found a clubby yesterday that someone let me take some measurements from, I measured from the floor up to the grille cut out, and also from the inside top edge down the the subframe, so I can get the nose height right with any luck, then it will just be trim/grind, repeat etc etc.
8th Apr, 2012 at 07:42:50pm
What were the measurements? I need to know where the teardrop mounts would have fitted, I'm fitting it on pins but would like a rough guide! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
9th Apr, 2012 at 09:13:29am
Surely you line up the tie bar mountings through the front panel? Measuring from the floor to the grill cutout will give you that one cars height - but rubber cones wear, people fit hi-lo's and BL weren't exactly known for their fantastic panel fitment.
9th Apr, 2012 at 09:40:25am
I also measured the height of the sills at the front and rear of the car :)
