| Home > General Chat > O/T BMW Mini Cooper S | |||||||
2nd Apr, 2012 at 05:50:37pm
I know a few on here have these, the supercharged one.
Edited by Tom Fenton on 2nd Apr, 2012.
2nd Apr, 2012 at 05:54:24pm
My mate said its a bit of a bitch he ended up with the whole front end off (the new mini comes to bits so easy its just bolts) and did it that way! it don't reallyt show a noticeable differnce down low but its better top end and also the superchargers do need rebuilding after certain amount of miles :( |
2nd Apr, 2012 at 06:03:11pm
i think you need a proper puller for these Tom, i think there heated and cooled onto the shaft making it a pig to get off Yes i moved to the darkside |
![]() 684 Posts Member #: 9590 Post Whore Derby |
2nd Apr, 2012 at 06:04:06pm
Well thats what my mate did with his and a custom air box and his made 196bhp Matt W
On 14th Mar, 2012 mw3 said:
Got a nice big delivery from Carl at Force Racing today. |
2nd Apr, 2012 at 08:11:43pm
Ian_W is your man to answer this Tom. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
43 Posts Member #: 9469 Member letchworth herts |
3rd Apr, 2012 at 06:59:38am
Company called gt tuning do the puller and the smaller pulley and does give ya more bananas |
![]() 263 Posts Member #: 40 Really Very Very Advanced 'Member' Stratford upon Avon |
3rd Apr, 2012 at 07:00:32am
its abit before my time these unfortunately, i've not played around that much with the mk1 MINIs but i know the pulley is press fit on there and it is bloody tight in that area so you may struggle with the engine in situ. |
3rd Apr, 2012 at 07:05:50am
They no longer sell them as a individual item only as part of there kit now !! |
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
3rd Apr, 2012 at 07:19:10am
Yes it can be done by its self but its not recommended to go any more that 15%, also it does require the special tool to remove it. If you look at places such as gt tuning, lohen and mstyle tuning you can buy stage 1 kits like you can for the proper mini. The turbo build has finally started |
54 Posts Member #: 8588 Advanced Member Yeovil |
4th Apr, 2012 at 05:55:13pm
Buy the parts from Lohen, very friendly & helpful. They can sell you the removal pulley tool as well. Job will take you aprox 4-5hrs. Warm the engine up first as this will help you remove the OE pulley. You can run a 15 or 17% pulley, but if you do decide to go for the 17% you may consider changing the intercooler to a higher spec. Check the bypass valve is sealing properly too as you can gain boost this way too if not correctly set at the factory.
Edited by Grahamxx on 4th Apr, 2012. Graham |
