| Home > Help Needed / General Tech Chat > Is anyone using motorcycle carbs? | |||||||
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
2nd Apr, 2012 at 10:15:53pm
I read an article that was linked on another forum (http://www.v-performance.com/products/air_fuel.html) where the claim was that motorcycle carbs are vastly superior to our beloved SU carbs, providing better fuel atomization, leading to better power and mpg. I also recall a forum member who was running a motorcycle throttle body on his turbo Mini and was making pretty big power there.
2nd Apr, 2012 at 10:28:58pm
Now that's weird I have read the same link tonight. It talks specifically about the mikuni hsr range. They even have a mini plate made up to fit a standard manifold.
Edited by gr4h4m on 2nd Apr, 2012. I run a supercharger and I don't care the TB is on the wrong side.
![]() 520 Posts Member #: 189 Post Whore Norway |
2nd Apr, 2012 at 10:42:31pm
Last year I had a set on my racecar. Its not a A-serie thou Edited by vegar on 2nd Apr, 2012. www.shag.no |
2nd Apr, 2012 at 10:43:51pm
Vegar are they r1 40mm choke? I run a supercharger and I don't care the TB is on the wrong side.
2nd Apr, 2012 at 10:50:11pm
The one on pics are 40mm Kehins. Not sure what bike thy are from.
www.shag.no |
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
2nd Apr, 2012 at 10:51:05pm
You could box them in for use under boost? Not so tidy but it's an easy way to make carbs work under presure. www.topcatcustom.co.uk |
2nd Apr, 2012 at 11:52:33pm
Nice, Vegard!
3rd Apr, 2012 at 06:51:31am
how about placing the whole carb settup in the plenum, no need to seal the carbs then
Edited by Brett on 3rd Apr, 2012. Yes i moved to the darkside |
3rd Apr, 2012 at 10:12:58am
The first is a 1050cc Abarth engine from my Autobianchi A112 Abarth. It made about 110 bananas with that 8-port setup.
www.shag.no |
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
4th Apr, 2012 at 09:28:12pm
´,m running 40 mm flatslides with asjustable powerjets, very drivable and good power
internationally known as "big" swede |
4th Apr, 2012 at 09:48:14pm
On 4th Apr, 2012 G13B said:
´,m running 40 mm flatslides with asjustable powerjets, very drivable and good power ![]() what are they from? On 7th Oct, 2010 5haneJ said:
5th Apr, 2012 at 05:07:20pm
from mikuni factory:) the are aftermarket flatslide carbs "mikuni rs 40" internationally known as "big" swede |
5th Apr, 2012 at 05:33:18pm
I'll be interested in seeing what the Fire engine makes, from what Ive read you should be able to make your target easily, On 28th Aug, 2011 Kean said:
5th Apr, 2012 at 05:50:25pm
I sure hope so. As far as I can see the biggest limiting factor is the small and they are located way out from each other so it is not possible to get very much bigger. I recon maybe 1 mm bigger valves are max before it reaches the bore
Edited by vegar on 5th Apr, 2012. www.shag.no |
319 Posts Member #: 1742 Senior Member essex |
5th Apr, 2012 at 06:05:01pm
alot of the bike carbs can be used for boost with a little re plumbing. There was a site which explained how but lost the link when my laptop died. will see if i can find it again. Robert has done this to his bike
Edited by jlay on 5th Apr, 2012. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
5th Apr, 2012 at 06:11:57pm
surely you can find some Tbs for use under boost as some bikes are turboed and supercharged
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
5th Apr, 2012 at 06:13:08pm
noticed this little set up currently for sale on ebay at the moment http://www.ebay.co.uk/itm/classic-mini-man...b#ht_500wt_1287 one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
5th Apr, 2012 at 06:13:39pm
oops cant get link to work sorry Edited by jlay on 5th Apr, 2012. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
5th Apr, 2012 at 06:14:31pm
thought id sort the link for you On 5th Apr, 2012 jlay said:
found a better link to it. http://www.turbo-bike.com/Pressurize%20Carburetor%20R1.html Edited by wez on 5th Apr, 2012. one day boost will be mine!
5th Apr, 2012 at 06:16:41pm
cheers My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
5th Apr, 2012 at 07:31:47pm
I looked at using bike carbs on my K head at first. From what I read you just have to pressurise the top chamber in the carb and the float bowl. (just take a feed off the plenum).
Edited by matty on 5th Apr, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
