| Home > Beginners Tech > Which Starter Solenoid | |||||||
![]() 71 Posts Member #: 2328 Advanced Member Nr Newmarket, Suffolk |
4th Apr, 2012 at 11:14:02am
Hi Guys,
100% BMW Free |
4th Apr, 2012 at 02:02:35pm
The four terminal is for a conventional distributor with points and a ballasted coil (the extra tag bypasses the ballast resistor wire when the engine is cranking so boosts the coil voltage).
4th Apr, 2012 at 03:28:59pm
Thanks for the quick reply Rod. I'm running Megajolt so no distributor. Guess that means I can go for the 3 terminal one. 100% BMW Free |
4th Apr, 2012 at 10:18:23pm
Yes, the single small terminal (flat tag) is just to operate it.
