| Home > Help Needed / General Tech Chat > Megajolt maps!!! - James Fawcett Site is bolloxed | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
4th Apr, 2012 at 06:03:41pm
Hello team!
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
4th Apr, 2012 at 06:11:36pm
I think I have a couple, what spec is your car? I'll see if I have one close to your engine.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
4th Apr, 2012 at 06:17:50pm
1310cc 10cc dished omega cast
4th Apr, 2012 at 06:22:55pm
standard rockers as well
4th Apr, 2012 at 06:24:10pm
A lot of people are using you johns map from the van, including me, pm him. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
4th Apr, 2012 at 06:34:09pm
is that a generic map then? Ill pm him On 10th Mar, 2012 theoneeyedlizard said:
4th Apr, 2012 at 06:38:58pm
Do a search for Megajolt and put John into the username box, read through and use the last one he posted Audi s4 b5 - 470bhp & 486ft lbs
4th Apr, 2012 at 07:07:37pm
4th Apr, 2012 at 07:09:24pm
this one:
Edited by Craigie-B on 4th Apr, 2012. On 10th Mar, 2012 theoneeyedlizard said:
4th Apr, 2012 at 07:20:26pm
Yes Audi s4 b5 - 470bhp & 486ft lbs
4th Apr, 2012 at 07:51:40pm
Thats the one Craigie. I don't have a copy of the map to hand so you may be better just typing it in.
4th Apr, 2012 at 08:05:21pm
Okay well Its basically a basemap that a friend of mine is going to re-jig to fit my specification :) hence why I was after a few of them
4th Apr, 2012 at 08:07:13pm
edit: dont worry I sorted it Edited by Craigie-B on 4th Apr, 2012. On 10th Mar, 2012 theoneeyedlizard said:
4th Apr, 2012 at 08:08:24pm
Double post Edited by bennyy on 4th Apr, 2012. Audi s4 b5 - 470bhp & 486ft lbs
4th Apr, 2012 at 08:08:32pm
John what was John sleath like with the mj?
On 4th Apr, 2012 John said:
Thats the one Craigie. I don't have a copy of the map to hand so you may be better just typing it in. I take no responsibility if it mullers your motor but it worked for us on the van. Still it is no substitute to a proper RR session with someone who knows what they are doing when it comes to spark maps. Audi s4 b5 - 470bhp & 486ft lbs
4th Apr, 2012 at 08:10:17pm
He was pretty decent with it. Did a bit of tweaking back and forth with it. He added a couple of degrees in the 3500rpm+/200kpa+ area since the above map. If something is worth doing, it's worth doing half of. |
4th Apr, 2012 at 08:12:29pm
He sounds good, knows his stuff from what I could make out when I spoke to him. definately be seeing him. Audi s4 b5 - 470bhp & 486ft lbs
4th Apr, 2012 at 09:34:26pm
On 4th Apr, 2012 bennyy said:
He sounds good, knows his stuff from what I could make out when I spoke to him. definately be seeing him. let me know when you go see him ill come too, :) Yes i moved to the darkside |
5th Apr, 2012 at 06:25:41am
Probably just go to book a session I've chatted with him before and got a good set up and knows his onions. Audi s4 b5 - 470bhp & 486ft lbs
