| Home > Help Needed / General Tech Chat > Would this spec be okay? | |||||||
96 Posts Member #: 9757 Advanced Member Solihull |
6th Apr, 2012 at 09:13:32am
I have been offered a 12g940 head with the following spec and was wondering if it is okay?
6th Apr, 2012 at 10:13:15am
looks ideal, but you'll want to check where you compression ratio will end up with the bottom end you want to use, although with 27cc I cant see a problem On 28th Aug, 2011 Kean said:
6th Apr, 2012 at 10:33:41am
Okay cheers |
6th Apr, 2012 at 03:59:06pm
Depends on the quality of the work, & if it's been used at all check that the ex valves aren't sunk as you can't go up an ex size to reclaim the seat without offsetting the valve.
