Home > General Chat > what's it worth?
wolfy
Member #: 8939
Banbury, Oxfordshire
afternoon,
wondering what the mini is worth, as it needs to go.
the spec is as follows...
1970 tax exempt mk3 in cherry red, fg front, 10" steels (not useable) all glass, paint okay, needs a polish now. the only rust is on the drivers door, a tiny bit near the bottom. the rest was sorted by me 3 years ago.
freshly built southam mini metro centre 1380
straight cut close ratio gearbox (tran-x gear kit)
centre oil pick up pipe, 4 pin diff
3.7 cwp
straight cut drops
73.5mm bore, omega pistons, lightened con rods, wedged,blanaced,cross drilled crank
new cam followers, water pump, pushrods, brand new 649 camshaft
cooper s rockers, southam trackday head & richard longman split webers on manifold
kad damper & pick up bracket/sensor. med lightweight backplate, alloy vernier duplex (the stupidly light one) grey clutch, lightweight flywheel, nippon denso alternator (brand new) & fiat cinq rad (brand new)
powdercoated lightened & welded front subframe, new bushes, dsn mounts, new engine mounts, minisport 7.9" 4 pots, vented discs & hoses, new brake pipes, adjustable tie rods, rose jointed bottom arms, new top arms
tdk racing 2 piece front end, well fitted, cobra classic bucket seats, black seat belts, black rear seat with red piping. no dash, no carpet. ally miglia style bulkhead box, rear subframe and rear brakes all present, new drums and shoes etc.
and what it looked like when it was last polished
Edited by wolfy on 7th Apr, 2012.
dazibee
Member #: 1356
TRURO, CORNWALL
Price? More info needed. Is it a late 80's mini on a 1970 plate?
1994alex
Member #: 9757
Solihull
I would probably say around 2500-2800
I could be wrong though
wolfy
Member #: 8939
it probably is a late 80's shell with an earlier number plate. not that it matters.
benspickup
Member #: 9608
Lincolnshire
Any idea what sort of umph the engine has? Have you had it running recently? Cheers Ben
1380rich
Member #: 9766
Warwickshire
No!!! You can't sell it! Only needs a bit to get it finished :( sell that new car you've bought *wink*
Avon 2010 class c 3rd
wolfy
Member #: 8939
dunno what kinda power it'll have and its never been run, as rich says (and he should know its with him) it only needs a little to get it driveable. due to unforeseen circumstances, i need money desperatly. rad needs mounting, megajolt, wiring loom installing(brand new) and a dash,carpet and some wheels.
dazibee
Member #: 1356
TRURO, CORNWALL
If you are asking how much a 1970 Mk3 is worth when it is really a 1989 car then yes it does matter a lot.
benspickup
Member #: 9608
Lincolnshire
Would you be interested in just letting the engine go? What would you be happy to take for it? Any receipts or photos of the engine/ box build? Cheers Ben
