Home > General Chat > Short Height Pistons
Simon
Member #: 1865
Norwich, Norfolk
As regular readers will know I've knackered a piston from det and looking for a replacement set of 4 just incase any of the others have suffered too.
I can't afford to strecth to forged so going for some cast Omegas, 73.5mm, MED seem to be the cheapest at the moment at £300 however I have 2 choices and wondered what peoples thoughts on the short height ones were?
My current pistons are 13cc (11cc resized to 13cc), I was thinking of getting the 11cc short height ones.
Standard compression height of 1.498", short compression height of 1.426"
http://www.med-engineering.co.uk/catalogue...istons-die-cast
If you do anything I'd keep the pistons flush with the deck and dish them out a bit.
Nick
Member #: 154
Midlands
there's an engine sat on my garage floor that was running 20psi and just shy of 200 nana's on flat top short height pistons.
It wouldn't bother me running them down the bore to drop the compression.
wez
Member #: 9271
Stoke on Trent
i've seen them run almost a couple of mm down the bore with no issues.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Flush all the way *wink*
Just because it runs with no apparent issues doesn't mean it's right.
supermotolee
Member #: 2153
kings langley
squish?
Short height pistons are for use with long stroke engines. Dont use them to lower compression, its not the right way of doing it
You're already on 7.9:1 anyway!
jlay
Member #: 1742
essex
yep as said squish its nice to keep this tight as it is supposed to help stop ringland damage. The n/a engines are standard approx .020" down the bore but with the turbo engine they were flush (or as close as) and i was to trust this was the reason why.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
imo if its set up right you should not have ring land problems in the first place, and i dont mind trading squish for lower cr right or wrong, i think grinding out the beak in the combustion chamber alot worse than running 20thou down the bore its only the same as a thicker head gasket
Edited by Brett on 29th Apr, 2012.
Simon
Member #: 1865
Norwich, Norfolk
i see, so this is one of those controversial subjects then!
supermotolee
Member #: 2153
kings langley
Ask a question about decompression plates *wink*
My personal thoughts on the matter is to run the pistons flush with the deck and sort your CR out with the piston dish/head chamber.
Simon
Member #: 1865
Norwich, Norfolk
Can someone help me out with my new CR calc.
Previously it was 7.9:1
1380 cc
26cc Head
13 cc Piston dish
3.8 cc Head Gas
7.2 cc Ring Lands
Now:
1380 cc
26cc Head
11 cc Piston dish
3.8 cc Head Gas
? cc Ring Lands
Pistons are 0.5mm (0.0196") down the bore. (cast omegas)
I make it 8.87:1
7.72cc for the ring lands?? it should be under 1cc
Edited by Joe C on 29th Apr, 2012.
Simon
Member #: 1865
Norwich, Norfolk
thats what Benross calc'ed for me previously when my pistons were further down the bores "heres my new calc which the cc in the ringlands is 4cc and the piston down the bores is 3.2cc making combined 7.2cc"
Even 1cc for the ring land volume is excessive.
Measure the bore diameter. Measure the piston crown diameter. Measure the crown height from top of top ring to top of piston. work out the bore area. Work out the piston area. Multiply Bore area but the crown height. Multiply piston area by the crown height. Subtract piston crown volume from bore crown volume. The result is the ring land volume, and I have not yet worked out a ring land volume greater than 0.5cc
Now:
1380 cc
26cc Head
11 cc Piston dish
3.8 cc Head Gas
? cc Ring Lands
Assuming 0.5cc for the ringland I get 8.6-1.
Simon
Member #: 1865
Norwich, Norfolk
ignoring the the piston for a second, bore area X 0.5mm (piston top down the bore) = 2.12cc's on its own, correct?
thats where the 3.2cc came from previously as my pistons were further down the bores.
so i need to know the omega measurements to get that cc calc'd and added to the 2.1cc, which typically i didnt measure before fitting.
Bore area minus piston area multiplied by the hight of the piston crown from the top ring
Ring land volume is the volume between the piston and the bore above the top ring.
Deck volume is the volume above the piston. (piston down the bore)
Dish volume is the volume in the piston
Gasket volume is the volume in the gasket itself
head chamber volume is the volume in the cylinder head
Total chamber volume is the sum of all the above.
As Phil mentions assume 3.4cc for the head gasket and 0.5cc for the ring lands. If you are saying your pistons sit 0.5mm down the bore, this is not ring land volume, it is deck volume.
Edited by Sprocket on 29th Apr, 2012.
you mean 3.8 head gasket ?
erm yep thats the one
Johnny
Member #: 6926
Accrington
as for squish, if you taper the head to where it meets the piston in the squish area, wont this eliminate squish?
for a very over exaggerated example, if the head chambers were round and not kidney shaped.
