| Home > Help Needed / General Tech Chat > Pics of harness mounts in floor? | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
9th Apr, 2012 at 11:16:09am
Does anyone have any pics of how they have fitted the anchors for the bollock straps for 6 point harnesses?
www.topcatcustom.co.uk |
9th Apr, 2012 at 04:04:25pm
How far from the floor is the seat??
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
9th Apr, 2012 at 07:04:05pm
you could weld the captives in the inner sill and tunnel as and where you need it for the lap belt
David. |
10th Apr, 2012 at 04:19:34pm
Sorry just seen the replies.
Edited by topcat on 10th Apr, 2012. www.topcatcustom.co.uk |
11th Apr, 2012 at 08:49:49pm
is that due to your seat posissioning? because i know masses of cars which use the wrap around method, M-sport R2 kits are wrap around type and thats generic fit the seat where you need kinda kit David. |
11th Apr, 2012 at 09:33:56pm
No there is a tube running across under the front and another running under the rear of the seat, then the seat sits on ally side mounts, and the bollock strap hole is not far off slap bang in the middle.
13th Apr, 2012 at 05:54:26pm
Quick update, after not being satisfied with anything I could find, and testing a mount through my mini floor which stuck out further than anything else on the car, I have made up a set of these which I am going to use.
Edited by topcat on 13th Apr, 2012. www.topcatcustom.co.uk |
