Home > Help Needed / General Tech Chat > fitting kad 7.9 vented calipers
JT
Member #: 637
Hertfordshire
hi
i was trying to fit my kad 4 pot calipers earlier but i cannot work out how the spacers go
has anyone got a pic of how they fit please?
im using kad 4 pot's with 7.9" vented discs
thanks
josh
My build thread..
JT
Member #: 637
Hertfordshire
anyone?
do the spacers go on the inside or the out side of the caliper?
they only seem to go on the inside but if i do that then it fouls on the disc!
and the bolts seem to be to long?
any help appreciated :)
thanks
josh
My build thread..
1380rich
Member #: 9766
Warwickshire
Mine went between the hub and the caliper, can't see any other way it could go. Have you rang kad? Really helpful when I wasn't sure about fitting mine
Rich
Avon 2010 class c 3rd
Scruffy
Member #: 328
Seaford Rise, South Australia
I think some pics might be in order here. Spacers will only be between the calipers and hubs.
On 5th Sep, 2011 Vegard said:
JT
Member #: 637
Hertfordshire
ok i will get some pics up at the weekend.
thanks
josh
My build thread..
JT
Member #: 637
Hertfordshire
iv had another look and basicley it looks like it will fit fine without the spacers.
the only problem with that is the bolts are too long, but i suppose i can always use standard bolts.
i just find it strange that the fitting kit KAD supply does not fit my mini!?
thanks
josh
My build thread..
jamie@thefatgarage
Member #: 9345
Sheffield
Are you using mini drive flanges? If you have metro ones if affects the position of the caliper in relation to the disk.
JT
Member #: 637
Hertfordshire
these are what im using
http://www.minispares.com/Product.aspx?ty=...id=36942&title=
My build thread..
jamie@thefatgarage
Member #: 9345
Sheffield
Wrong ones for mini calipers I think. The position of the disk relative to the hub is different on metros. I had metro 4 pots on the shell I started with and bought new alloy mini calipers and hubs, ended up having to buy mini flanges too to make it fit.
JT
Member #: 637
Hertfordshire
bugger
they look like they will fit fine without the spacers, just need shorter bolts.
i will get a pic up tomorrow.
thanks
josh
My build thread..
rich13801
Member #: 2150
Theres the minispares instructions no good for kad but may help someone
Edited by rich13801 on 14th Apr, 2012.
