Home > Help Needed / General Tech Chat > Brake limiting valve
Ayone know the size of the big copper washer used in the brake limiting valve found on the rear subframe mk2's ?
I check with minispares but the don't sell them, and a mate has an issue with his, I didn't want to dismantle it unless I had a spare.
Thanks
Graham
if its copper it'll squash back down if retightened,you could always re aneal it before re using,
carl
As above, just re use it, but DO aneal it before re using it.
Heat it until cherry red all over, then either, let it cool naturally, or drop it into a bucket of water.
I don't think it's got the original washer., it has one of those with a rubber centre. Someone else's attempt at a fix....
