| Home > Help Needed / General Tech Chat > FUEL PUMP? | |||||||
556 Posts Member #: 7029 Post Whore Wickford Essex |
14th Apr, 2012 at 11:50:38am
HI all
14th Apr, 2012 at 12:30:01pm
Anti run on valve stuck open, or possibly carb balance pipe is perished. Anti run on valve is more likely. Just disconnect the pipe from the valve and block the pipe to see if it fixes it. |
14th Apr, 2012 at 12:37:54pm
Sounds like you have used up your dashpot oil to me Yes i moved to the darkside |
14th Apr, 2012 at 12:41:58pm
Will have a look ... |
14th Apr, 2012 at 12:43:00pm
On 14th Apr, 2012 metroturbo said:
Anti run on valve stuck open, or possibly carb balance pipe is perished. Anti run on valve is more likely. Just disconnect the pipe from the valve and block the pipe to see if it fixes it. Will take a look .... |
14th Apr, 2012 at 01:26:12pm
I will have a look in a bit steve as i think i have a good fuel pump i can pop in the post for you to try
14th Apr, 2012 at 02:24:21pm
I had a mate with a metty turbo that did this, it was back when I dint know much about cars so we didnt find the cure....
14th Apr, 2012 at 03:51:05pm
On 14th Apr, 2012 wolfie said:
I will have a look in a bit steve as i think i have a good fuel pump i can pop in the post for you to try That would be great mate . |
14th Apr, 2012 at 06:28:03pm
If the car drives but dies when you start to build up boost, I would be very surprised if it is the fuel pump. Did it drive fine below 2000 rpm?
Edited by metroturbo on 14th Apr, 2012. |
