Home > Help Needed / General Tech Chat > NGK plug fouling issues
almichie
Member #: 2065
Sooooo I went out in the week in the mini, got the itch and turned up the boost. I did stop and switched the needle first. The car started coughing and ultimately ended up in what I think lead to the plugs being fouled.
Now I'm on my 3rd set of bpr7es plugs in less than 1k miles, which I think is a little excessive.
They seem very sensitive to getting wet and don't recover. Are there any alternatives to these? Any feed back on the fouling issues? I'm actually tempted to try a hotter plug in an attempt to avoid the fouling problem?
Thanks in advance, Al
Shaft seems nice and snug
In my experience one they have fouled they are never the same, and the really dont like getting fuel on them.
give champion RN7YC'S or Denso W22EPR-U'S a go.
Yep. I've got through plenty of these. They are really sensitive.
Go for the Champions suggested by Joe.
almichie
Member #: 2065
Thanks guys - I've just ordered a set of champions as suggested. I'll report any findings.
scott the joiner
Member #: 9229
newcastle upon tyne
I've had bother with ngk plugs aswell think iam going to try 1of the above suggestions 2
Nick
Member #: 154
Midlands
me and kean have always had issues with the 7's fouling easily, i've been running the same set of 6's for a couple of years now though with no issues.
almichie
Member #: 2065
Not had any problems with det on the 6's?
That was my only concern - they wouldnt dissipate the heat away from the tip fast enough at higher boost levels
A spark plug won't cause det.
The problem here is not the spark plug, it's the fuelling. I agree that the NGKs do not like to get wet and don't recover. But to be fair why should they?
I use 7s in my road cars, never had a problem. I use 8s in the hillclimber. We've knackered a few over the years, but now the fuelling is right they are not a problem.
http://www.ebay.co.uk/itm/290693378808
I use these. Only ever managed to muller one in the van by leaving the choke out for about 20 mins in the fire up lane at Avon.
ive managed to kill 1 or 2 of them aswell, ive been running 6es since no problems
scott the joiner
Member #: 9229
newcastle upon tyne
Iam running a bit rich at top end (wot) down to around 11-high 10s afr on my aem which I don't mind at the minute as more boost should help sort this out but I think this is causing my plug problems to be honest
tadge44
Member #: 2500
Buckinghamshire
NGK,s seem to last about 2k in my engine then they just "fade" -- a new set restores performance instantly.
I,m told the NGK, s with three side ele ctrodes work better, but they are ahell of a price.
