Home > Help Needed / General Tech Chat > GT1549
turbochargedstu
Member #: 908
gateshead
anyone had a look at one of these? tried the garrett website with no luck. fits a rover 25 tdi and seen a brand new one fairly cheap. wouldnt mind trying it out if it will work. got a fiesta rs turbo i/c to run through it too.
stu
balls to the blower!!!
pinkyandnobrain
Member #: 2588
Pretoria South Africa
I'm using one in my road mini. On a custom manifold it fits with no baulkhead mods.
I can't compare it to anything because its my first turbo car, but its boosts from very low and I'm running close to 15psi and it seams happy.
"Try to take over the world!"
It cant bee too far off a t2 size and may have a map for it, i will look when im at home
turbochargedstu
Member #: 908
gateshead
cheers brett. not sure if its oil cooled only or both oil and water. is it wise to have oil cooled only turbo on a mini?
Mine is oil cooled only so is the standard T3 and alot of the T2s are only oil cooled aswell
jlay
Member #: 1742
essex
oil cooled is easier to fit but people fit water cooled in minis no problem
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
turbochargedstu
Member #: 908
gateshead
sweet. means i will have to make my own manifold but im sure i could manage.
its the gt1548 map ive got, still cant be too far of that imo, have a look on garretts site, its on there too
I bet the 49 is the same as the 48 but with a different flange or some other special.
OR, it has the same compressor as the 48, but a smaller/larger turbine.
Either way, an inspection to se what the A/Rs are and a measure of the impellers will give you an idea.
If it's cheap enough, in good nick and has a useable flange, then I'd buy it. Worst case is you buy it, measure it, find it's too big/too small and have to sell it on.
jlay
Member #: 1742
essex
if you can get numbers i use a turbo parts site to run what turbines they have in. I did this the other day on the t2 i bought to find they all had the same exhaust side just different inlet size.
turbochargedstu
Member #: 908
gateshead
what numbers you need? might just order one and see what i can do.
