| Home > General Chat > Oil Relief | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
17th Apr, 2012 at 07:55:17pm
Does anyone know how to remove the oil pressure relief seat insert from the block. http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
17th Apr, 2012 at 08:03:25pm
Yeah, loads probably This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
17th Apr, 2012 at 08:20:19pm
i didn't know there was a seperate seat , i assumed it was machined into the casting, |
17th Apr, 2012 at 08:25:26pm
On 17th Apr, 2012 fastcarl said:
i didn't know there was a seperate seat , i assumed it was machined into the casting, http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
17th Apr, 2012 at 08:30:21pm
can you show me, |
17th Apr, 2012 at 08:50:44pm
Tap some thread into it + long bolt and drift it out Yes i moved to the darkside |
17th Apr, 2012 at 09:00:43pm
p/n 2A797
can you show me, |
17th Apr, 2012 at 09:02:31pm
Although I'm not sure it seats on it as opposed to just fits in it.. |
17th Apr, 2012 at 09:36:05pm
Run a M10 tap inside, then use a slide hammer with an M10 bolt, job done :)
17th Apr, 2012 at 09:37:59pm
Ah, never knew that was a seperate item, why do you
17th Apr, 2012 at 10:31:21pm
It's damaged
Ah, never knew that was a seperate item, why do you want it out, carl http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
![]() 85 Posts Member #: 3600 Advanced Member Gateshead |
18th Apr, 2012 at 05:13:55pm
On 17th Apr, 2012 Gavin Wakely said:
Does anyone know how to remove the oil pressure relief seat insert from the block. All of the information that you need should be available on this page I think (http://home.earthlink.net/~roygmisc1/convert1/convert1.html). It even shows a cross section with the seat. Simon Edited by svrdaniels on 18th Apr, 2012. |
18th Apr, 2012 at 06:27:21pm
Ah, never knew that was a seperate item, why do you want it out, carl Another part to add to your Ti parts list.
319 Posts Member #: 1742 Senior Member essex |
18th Apr, 2012 at 06:27:35pm
wow you must really want to use an auto block to do all that work. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
