| Home > General Chat > What have I done? MGB problem | |||||||
288 Posts Member #: 6267 Senior Member Bristol |
19th Apr, 2012 at 04:28:32pm
I have an MGB GT which is my daily driver, it has had an occasional misfire which would come and go at random so I decided to take a look at the dizzy. I found the cap in a poor state and the wire from the coil to the condenser was just pushed in and making a poor contact. I replaced the cap, rotor and condenser on my 998 Mini years ago but only ran it for a couple of hundred miles before changing to electronic. As they are both 45D4s I decided to change over the cap, rotor and condenser as the part numbers were all the same, I also cleaned everything up and oiled all the relevant bits.
19th Apr, 2012 at 04:40:16pm
back to basics - did you tighten the dizzy up after setting the timing? |
19th Apr, 2012 at 04:45:41pm
Condenser, even if is newish:
19th Apr, 2012 at 04:49:09pm
Yes, I tightened it up initially, I have now slackened it off but no amount of moving it around will make it run anywhere near ok. It is so bad that having the timing massively retarded makes almost no difference. I have checked all the obvious things I can think of such as firing order and connections. |
19th Apr, 2012 at 04:53:08pm
Could a bad condenser cause a car to barely run at all, I thought they just smoothed out the spark? The thought had crossed my mind but it would seem strange that 6 years of sitting in my garage would cause it to fail.
On 19th Apr, 2012 Paul S said:
Condenser, even if is newish: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=337996 |
19th Apr, 2012 at 05:09:17pm
The symptoms sound like condenser failure. 6 years sitting in a garage is probably worse than beng in use. Is the garage damp? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Apr, 2012 at 05:19:20pm
I have repaired the wire on the condenser I removed so as soon as it stops raining I will go and test it out, I hope it is that as it will be a simple fix.
19th Apr, 2012 at 05:38:59pm
another vote for condensor here... they really are temramental little C**T's On 28th Aug, 2011 Kean said:
19th Apr, 2012 at 06:08:42pm
As above, points and condenser really are pretty duff, if it's your daily driver then I'd definitely lay out on an electronic ign kit.
19th Apr, 2012 at 06:09:56pm
We've fitted electronic ignition to ours. Best £30 spent on it.
In the 13's at last!.. Just |
19th Apr, 2012 at 06:36:03pm
It's been my plan to switch to electronic ignition, I just haven't decided which one to go for yet. There seems to be a lot of debate over which is best, which are terrible etc. I've got other cars I can use so it's not a massive problem other than the MG blocking most the cars on the drive! I only use the MG as it is the most fuel efficient and it has an 8-Track :) Thanks for the help so far. |
20th Apr, 2012 at 07:04:08am
I've just swapped the condenser back to the old one and it runs beautifully again. I never knew a bad condenser could cause such severe problems or have such a short life, it would have saved me a lot of time yesterday to know that as I was sure it was something I had done. Thanks for help everyone, it is very much appreciated. Time to buy electronic ignition I think. |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
20th Apr, 2012 at 07:11:52am
No.1 B series resource now as well |
