| Home > Help Needed / General Tech Chat > nuts and bolts!!! stainless steel or high tensile zinc plated? | |||||||
19th Apr, 2012 at 07:06:30pm
hi
My build thread..
19th Apr, 2012 at 07:16:18pm
Stainless is corrosion resistant, but work hardens which can lead to failure, so should not be used on any stressed or safety critical joint, I.e. Suspension, brakes.
19th Apr, 2012 at 07:22:55pm
thanks tom
My build thread..
432 Posts Member #: 7856 Senior Member Essex |
19th Apr, 2012 at 07:27:49pm
On a side note (for Tom this is really), what is your opinion on stainless wheel nuts?
296 Posts Member #: 7876 Senior Member Walsall West Midlands WS1 2DW |
19th Apr, 2012 at 07:46:08pm
I fitted smiffy's bits stainless bolts throughout incl. subframes but the cars not on the road yet are you saying that they could be dangerous? Patina=old and knackered and won't clean up |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
19th Apr, 2012 at 07:57:39pm
I've run my car App 2000 miles with stainless bolts in the sub-frames, no problems so far, on saying that not right keen on them they don't seem to tighten up all that good, even when you use a lot of force they seem to lock up before they are really tight..
Edited by nala56 on 19th Apr, 2012. Main Build
19th Apr, 2012 at 08:08:32pm
Steve A, I believe Tom is saying they are dangerous, there was a thread on the use of stainless steel bolts being used to hold split rims together, if you can find that it may be helpful for you! |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
19th Apr, 2012 at 08:35:54pm
its the type of joint that you have to consider for stainless. alot of suspension components are held in shear. id definatly be choosing HT plated over stainless.
David. |
19th Apr, 2012 at 08:57:46pm
Basically if it is stainless in tension, in a low stress application, and will not see fatigue cycles, then it "probably" will be OK.
19th Apr, 2012 at 09:28:16pm
The only 2 places I wouldnt use stainless bolts are the joint between the bottom to and tie bar and front brake callipers. I used ss everywhere else I seriously doubt it! |
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
20th Apr, 2012 at 07:35:13am
Am sure I was told that when people IVA cars or maybe even MOT them, they will/should fail if fitted with stainless bolts with anything to do with the brakes and possible suspension? www.topcatcustom.co.uk |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
20th Apr, 2012 at 08:31:18am
It all depends on using the correct grade of bolt (the A number) this Pdf explains in some detail.
Banned User 2 Posts Member #: 11291 Junior Member india |
11th Jan, 2016 at 07:38:32am
if you find those nuts and bolts then its goof but if you want to buy fine quality nuts and bolts then try Asian or middle east countries because they serve best things in cheap price. for example you can get your stuff by filling this simple form at here http://www.pankajinternational.com/enquiry-form |
11th Jan, 2016 at 09:17:24am
the real question is whats lighter?
11th Jan, 2016 at 09:36:12am
On 11th Jan, 2016 jasona said:
if you find those nuts and bolts then its goof but if you want to buy fine quality nuts and bolts then try Asian or middle east countries because they serve best things in cheap price. for example you can get your stuff by filling this simple form at here http://www.pankajinternational.com/enquiry-form Bye
11th Jan, 2016 at 09:54:41am
Lol I have started posting on Instagram also my name on there is turbomk1golf
321 Posts Member #: 10371 Senior Member leicestershire |
14th Jan, 2016 at 08:21:43pm
well thats a different stunt for a survey to rob your bank haha |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
14th Jan, 2016 at 10:37:29pm
Haha! I didnt dare click! His 1st post/introduction seamed dodgey - cant find it now.. i take its been wiped.. good as tom says bye! 😃 Edited by D4VE on 14th Jan, 2016. On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
17th Jan, 2016 at 08:34:27am
Bang and the dirt is gone must of been some strange first post wouldn't surprise me if he's back soon |
