Home > Help Needed / General Tech Chat > Smell of fuel in boot
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Renewed seal on sender unit.
Used a thin film of sealer on the top access for in side fuel pump.
Inside fuel pump fitted.
All pipes are new.
But still I get a smell of fuel inside the boot, has any one had this trouble or any ideas would be helpful
Thanks in advance guys..
Main Build
Upgrade to Turbo
JT
Member #: 637
Hertfordshire
sounds simple but is the breather breathing out side the car?
My build thread..
Amp
Member #: 7856
Unlikely, but I've had a neck rust through where it goes through the body, so vapours (and fuel) could get out that way?
nala56
Member #: 9661
Yes mate, breather is through the boot floor..
Main Build
Upgrade to Turbo
nala56
Member #: 9661
Looked ok when I had the tank out..
Main Build
Upgrade to Turbo
evolotion
Member #: 83
Glasgow, Scotland
breather through the boot floor will still get you the smell in the boot as the vapours will linger under the car even when rolling, i stopped it on mine by running the vent to near enough at the rear valance. And rubber fuel hose (inc braided) will geenrally sweat a teensy tiny bit of fuel, enough to notice the smell lol.
Denis O'Brien.
nala56
Member #: 9661
I've used flouro *happy* lined silicon fuel pipe, do you think that may be sweating a fuel smell?..
Edited by nala56 on 19th Apr, 2012.
Main Build
Upgrade to Turbo
Floral
*hehe!**wink**wink*
Mattlad
Member #: 1871
Chesterfield, Derbyshire
I Thought the smell of petrol in a mini was normal! *hehe!*
nala56
Member #: 9661
Yes beginning to think your right, I've changed from a 5.5 ltr tank to a 7.5 ltr spi tank, didn't notice the smell with the old tank and I'm sure I would have..
Main Build
Upgrade to Turbo
Mr Joshua
Member #: 1954
Luton Bedfordshire
As standard the breather should exit through the hole cut in the boot flour under the passenger rear light cluster and drop down and almost clear the rear valance.
Own the day
