Home > Wanted > Turbo oil feed!
jcsmarttec
Member #: 9404
Cambridge
Really need a turbo oil feed pipe. Braided type. Thanks!
Go to your local hydraulics specialist. You want a 3/8 UNF banjo bolt on one end and a 1/8 NPT straight fitting on the other end. It will be cheaper than one from an off the shelf supplier (That's assuming it's going on a T3).
Exactly what I did andy, I took my banjo bolt from my turbo and also took the take off from the block with me and said "make me a pipe" hey presto, cost me £17 irrc.
Mike
bennyy
Member #: 9037
Doncaster, yorkshire
I got everything from eBay, it depends what turbo you have .
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Paulham
Member #: 9654
NW London
What length of hose did you use?
bennyy
Member #: 9037
about 3/4 of a metre for mine
jcsmarttec
Member #: 9404
Cambridge
Thanks to you all for the replys. It's going on a t3 so I'll do as said. Cheers again!!
