Home > Wanted > 1275 Crankshaft and rods
MatthewPettitt
Member #: 9237
Banbury
I have now sorted myself a block.
But now I require a Crank shaft and rods for it.
jameswildcooper
Member #: 1355
Leicester
ive got a crank.... pm me if interested
I've got a set of rods, still with a set of pistons attached £25.
jameswildcooper
Member #: 1355
Leicester
MatthewPettitt
Member #: 9237
Banbury
those rods sound good, would you be willing to sell them without the pistons? As I'm reboring any way, and posting them would be a little cheaper too. If you're alright with posting?
I can cut the pistons off by all means, but do not have the facilities to press out the pins.
MatthewPettitt
Member #: 9237
Banbury
hmmm, not sure now if I want then cut off, don't really fancy risking the rods getting damaged.
so I'll have them with the pistons.
PM me with some details and all that.
Sit the piston over an open vice and drift the pin out with an old socket or something. It doesn't matter of the pistons get damaged as they are going in the bin.
I've got a couple of practice rods lying around so will go and have a try.
Nice tip Andy, the rods are now free of pistons with no contact at all.
MatthewPettitt
Member #: 9237
Banbury
Rods sorted.
And I'm afraid that the Crank is a 12G1505 which doesn't have the rolled radii in the bearing joirnals.
which is the one I'm after.
sorry for any confusion.
I'm after a CAM6232
