Home > General Chat > bulk rings / synchros
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
I bought a fancy new Molybdenum coated gear set for the new build but my question is dose mini mania sell some bulk rings / synchros that match the gear set i have and if not who dose i cant seem to find them anywhere that say they are good to use on Molybdenum coated gearsets except mini sport and they are out of stock with no expected delivery date so can i use any good quality ones?
Use the best old ones that you can lay your hands on. The modern ones aren't as good as the OEM ones.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
ill have a dig in the parts boxes..
also im ether a re tard or there is an easier way to compress the springs to assemble the main shaft? a tool or jig?
Yes wait for evolution to grow you an extra pair of hands. Or get someone to help lol
I managed with just two hands.
Just press the pins and the thrust washer drops enough to hold them in.
There's a good Minimania video on YouTube. Lots of bashing and crashing, but still good info.
Star Mag
Member #: 375
Leicestershire
I managed to get some rover ones from Minispares at the end of last year. Don't know whether they still have any.
They are out of stock at the moment.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i watched the videos he makes it look easy haha im yet to have round two with the thing..
as far as good old ones go i can only find 2 that id be happy to put in but then agen im one of those people that like things to be perfect..
When rebuilding my box I used the originals rather then the set of steel minispares ones I had, the new minispares ones looked worse then the 40k ones I re-used.
Next rebuild I guess I'll have to bite the bullet and fit the steel minispares ones.
Edited by minimole23 on 28th Apr, 2012.
Flame Red
Member #: 6267
When I rebuilt my box I bought new genuine Rover bulk rings from Somerford, they were half the price of Mini spares. I don't know if they still have any left.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Use a plastic tie around the body of the syncro, get the outer part on a flat surface, slide the middle down with springs and balls resting on the outer ring followed by a plastic tie, make sure its pulled tight on the middle slide it over the ball bearings, then push the syncro together, that's how I do mine..
Main Build
Upgrade to Turbo
