| Home > General Chat > megatwat cable | |||||||
23rd Apr, 2012 at 09:42:14am
Is it posssible to make a cable by splicing a rj11 to a usb?
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
23rd Apr, 2012 at 10:16:52am
rj11>serial is about 6 pounds from MJ i think and the serial > usb 20 from maplins at worst; wheres the 50? |
23rd Apr, 2012 at 10:22:05am
I wanted to avoid goin to serial and then to usb. The 1 I used was rubbish and always disscontected from the laptop 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
23rd Apr, 2012 at 10:33:53am
buy an old laptop then, personally going from rj11 to usb your gonna struggle as there are no drivers for it; that im aware and im sure it would be more readily avaliable if it was easy enough.
Edited by t@z on 23rd Apr, 2012. |
23rd Apr, 2012 at 10:38:26am
Personally i would use a rj11 to rj45 patch lead and put a rg45 to usb adpater on the end
23rd Apr, 2012 at 10:43:03am
I'd just use a laptop with a real serial port If something is worth doing, it's worth doing half of. |
23rd Apr, 2012 at 10:43:20am
Probably cheaper than pissing about with adaptors too lol. If something is worth doing, it's worth doing half of. |
23rd Apr, 2012 at 10:51:52am
I like wolfies idea seems simple 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
23rd Apr, 2012 at 11:42:12am
i am not saying it will work but cheap enough to try
23rd Apr, 2012 at 12:23:53pm
You cant just wire a serial signal into a USB port. It's not just a different shape port and getting wires the right shape to plug together that is the issue, it's a different signal. You need to either use a serial port, or buy a USB to serial converter which translates the signal to something a USB port and your serial device will understand. The RJ45 lan adapter also won't work as ethernet and serial are not the same signal either. |
