Home > Help Needed / General Tech Chat > Megajolt Rev dial and wiring diagram :) pleassee
Craigie-B
Member #: 9468
Wootton Bassett
Quick one Boys and Girls,
can the megajolt run the standard rev counter (the 3 clock type) if not what else will I need to incorporate for this to run lovley?
Making up my wiring loom today and want to know :)
Craig
Edited by Craigie-B on 23rd Apr, 2012.
Use the 'pip' output on the edis.
Craigie-B
Member #: 9468
Wootton Bassett
sweet :)
is this wiring diagram okay for my setup (im using hte hardcut limiter)
EDIT: ill put the tacho from the EDIS so please ignore it on the mjlr
adapted from:
http://www.autosportlabs.org/viewtopic.php...5c6f6e0411c56f9
Craigie-B
Member #: 9468
Wootton Bassett
okay how about this wiring diagram below guys:
I have put the tacho off the PIP and got rid of the "option switch" as I dont have a clue why I need it :/
Edit:
Heres the plug - this is all I believe I'll need:
any comments/advice/criticism/praise/donations to mini fund/smily faces/love/hate is welcome :)
michaelb
Member #: 7425
Hi Craig,
I have just finished getting my tacho to work and found the output from the edis module caused the tacho to read double the correct revs. I ended up taking an output from one of the coil inputs and this works OK. The tacho now reads the same as the Megajolt tacho.
I have a set of Seiko gauges in my car.
Carl S
Member #: 1761
Stalker
I also have Seiko gauges, my mini is a 90' Mayfair, and I had no trouble with the tacho output from Megajolt as apposed to using the PIP wire or a coil bank ground; it worked spot on.
Edited by Carl S on 25th Apr, 2012.
bennyy
Member #: 9037
Doncaster, yorkshire
Did you get this sorted craig? I am going to sort out my tacho in next day or so.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
I used the edis tacho out with my Nippon instruments.
bennyy
Member #: 9037
Which pin in that john?
the one that isn't opened up in the plug, next to the end.
bennyy
Member #: 9037
Oh yeah I remember you saying, have to drill it or something?
yes, we glued a wire into the plug
Mike-998
Member #: 9774
Buckinghamshire
I just used a wire that was in the EDIS? Its the green one, second from the bottom in this picture:
Some have the wire in some are blocked off.
Craigie-B
Member #: 9468
Wootton Bassett
I still haven't gotten around to it :'( mine are the smith guages (the ones with the 3 clocks?) Ill try the megajolt connection then if it doesnt work, try the EDIS.
bennyy
Member #: 9037
Drilled the edit plug, glued a wire in, ran it to my clocks, 2 second job now its all sorted. Cheers
Craigie-B
Member #: 9468
Wootton Bassett
Just for anyone else who reads this thread.
I have Smiths 3 clocks type rev counter and it works perfectly with the feed from the megajolt molex plug
