Home > Help Needed / General Tech Chat > abutment plate pics/help
jlay
Member #: 1742
essex
hiya i have collected bits as and when and have a turbo carb inlet ant now two abutment plates but they are all from different setups. The carb i have hat throttle one side and choke the other. The throttle is of the progressive type not the straight leter type and its on the o/s (driver side) of the carb. The abutment plate i have is both on one side (choke side) or the other one is throttle only on driver side like i need. I have seen a small pic of one with both on and the way round i need. Has any one got one they can take pics from different sides so i can copy. I know i can make something that will work but thought if i make it as an exact copy i might make a few. Thanks for your help james
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
jlay
Member #: 1742
essex
Not to worry made one. I didn't realise there were so many different ones.
