| Home > Help Needed / General Tech Chat > t2 query | |||||||
11th May, 2005 at 01:04:35pm
just been looking at all the other posts on this subject but am a bit confused, my bulkhead is already modified from the first build so would it be easier to just get an adaptor plate and use a t2 or get the mirage kit (i hear the manifolds dont flow well due to the compact space when pushing lots of power). Also can i use a t25 as there seems to be mixed opinions about whether these are good or not due to a/r size etc, cheers |
244 Posts Member #: 34 Senior Member |
11th May, 2005 at 06:11:07pm
11th May, 2005 at 09:59:25pm
cheers mate |
11th May, 2005 at 10:07:20pm
You also have to modify the actuator mounting (easy), need to sort out water pipes for the cooled turbo, get a oil feed made.
11th May, 2005 at 10:42:36pm
I stand corrected then, I thought the kit was lock stock.
11th May, 2005 at 10:50:19pm
coming soon......my comprehensive mirage fitting guide, the doc and pics are sat on my computer, i just need to post it all |
12th May, 2005 at 01:52:55pm
The term 'comprehensive' sounds like it means it! On 17th Nov, 2014 Tom Fenton said:
12th May, 2005 at 04:10:04pm
The mirage "kit" is just the exhuast manifold, turbo elbow and downpipe.
Edited by SumpNut on 12th May, 2005. |
12th May, 2005 at 04:15:59pm
Turbo Dave
12th May, 2005 at 04:40:05pm
12th May, 2005 at 09:43:24pm
thanx
13th May, 2005 at 12:21:10pm
the engine is out the car in bits, has anyone got a pic of the oil return surely its just a pipe to the block or do u mean to the gearbox? |
13th May, 2005 at 02:13:47pm
You should be able to get the oil return into the block using the Mirage kit. If you fit a T2 to the Metro manifold the Turbo sits somewhat lower and sorting a return into the usual place is more difficult, though possible as i found out.
13th May, 2005 at 02:48:32pm
cheers
