| Home > Help Needed / General Tech Chat > CARBON FIBRE CUTTING TOOL | |||||||
327 Posts Member #: 1145 Senior Member North Wales |
26th Apr, 2012 at 05:30:42pm
Awright guys. Nxt month im gone be ordering my curley carbon fibre dash.
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
26th Apr, 2012 at 05:52:20pm
I use a grinder with slitting disc, normal holesaw, and die grinder. All work well for me. www.topcatcustom.co.uk |
26th Apr, 2012 at 06:08:54pm
If your drilling holes using a twist drill, drill it the size you need with the first drill. Ive found that if you use a pilot drill, the second drill tends to snag up and it could cause the gelcoat/topcoat to crack around the hole. Edited by matty on 26th Apr, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Apr, 2012 at 06:11:09pm
ok lads will. Thanks for the tips |
26th Apr, 2012 at 06:20:35pm
I cut the holes for my gauges slightly smaller than needed and finished with a file to avoid any chipping.
In the 13's at last!.. Just |
26th Apr, 2012 at 06:50:37pm
For a long trim (like round the arches of a front end) I have a GRP blade for my jigsaw. Makes easy work with a neat edge. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
26th Apr, 2012 at 06:52:52pm
Can you put masking tape over it and mark where you want to cut to stop it from splintering and the gel coat cracking? The turbo build has finally started |
![]() 568 Posts Member #: 1200 Post Whore Bristol |
26th Apr, 2012 at 10:18:05pm
also put some wood or other backing material for drilling through iinto as it will help prevent breakout and splintering of the holes. |
1391 Posts Member #: 1686 Post Whore Oxford |
26th Apr, 2012 at 10:54:02pm
Use a fien type saw. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
27th Apr, 2012 at 05:24:24am
Wear a dust mask and eye protection, its nasty stuff I seriously doubt it! |
27th Apr, 2012 at 06:40:25pm
On 27th Apr, 2012 paul wiginton said:
Wear a dust mask and eye protection, its nasty stuff On 19th Feb, 2011 Miniwilliams said:
30th Apr, 2012 at 04:41:16pm
Thank you for the advice gents-i might get a local firm to do it-if it goes wrong they can pay for it. ha.
