Home > Beginners Tech > ramdon question about dump vavle
evilbutnice
Member #: 9174
colchester essex
hi guys
i have a 1293 mini turbo with a bailey dump vavle but was wounding if i could fit a flutter vavle insead or how i could make mine flutter? any ideas
evilbutnice
Member #: 9174
colchester essex
plus where i could get a flutter vavle from?
Flutter isn't anything changing a dump valve will do buddy. It's certainly nothing I'd ever want on my own car either!
Have a quick read:
http://www.balancemotorsport.co.uk/main.as...ages=dumpvalves
Edited by Carlzilla on 26th Apr, 2012.
evilbutnice
Member #: 9174
colchester essex
kl thanks for your help its just one of thouse things your hear it on another car etc etc lol
do you know whats a good dump vavle to have on a mini?
Diaphragm types are best on mini's, but I'm going to be fitting a piston type because it was cheap for a Bailey one!
The only problem with piston types though is that the rubber seal swells if fuel gets to it, and then the dump valve stops working!
jlay
Member #: 1742
essex
whats wrong with your bailey?
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
evilbutnice
Member #: 9174
colchester essex
nothing wrong with my one i think well it still works i just dont think it holds the boast under load when i really put my foot down as i am running 150bhp at 10psi..
MarkGTT
Member #: 1194
Shropshire.
150 @ 10psi fair play, What's the engine spec?
tadge44
Member #: 2500
Buckinghamshire
Thanks to Carlzilla and the link I now know the answer to a dump valve problem I was going to ask about on here.
All I need now is an adjustable dump valve.
Glad I could help bud!
