| Home > Help Needed / General Tech Chat > Help with hoses on the manifold and carb? | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
27th Apr, 2012 at 09:25:56pm
Okay so I know theres a thread around somewhere and it details what goes where on the carb, I either cant find this or the picture wont load anymore so I'm asking here:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
28th Apr, 2012 at 12:33:03am
The two bottom arrows on the top picture are the water cooling/heating pipes for the manifold; personal preference as to whether these are connected. top of the manifold is for things like boost gauges and megajolt.
Edited by Mike-998 on 28th Apr, 2012. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
28th Apr, 2012 at 06:31:56am
The two left and right on the manifold are the connections for the coolant supply to heat the manifold up. cut them of. The other one marked is for the servo vacuum hose on the metro. If you don't have a servo, you need to take this out. Then get an adapter and plumb your megajolt etc into the hole left behind.
28th Apr, 2012 at 09:51:41am
Ahh Thanks guys, I dont have a servo so will use that for the megajolt
