| Home > Help Needed / General Tech Chat > Help Turbo Oil Drain issue | |||||||
![]() 328 Posts Member #: 9107 Senior Member Devon |
28th Apr, 2012 at 06:51:04pm
Need some help, I discovered an oil leek today and have found that the Turbo oil drain is broken badly, its the alloy part that connects directly to the turbo, is seams tha flange that the silicone pipe goes on has detached from the alloy housing, looking closely it looks like its a pressure fitting, I can only think that the heat from the turbo has caused the casing to expand and therefore the sleve has come out ! , I have never heard of this happening before !.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
28th Apr, 2012 at 06:57:59pm
could try brazing it Done now needs redoing lol |
28th Apr, 2012 at 07:46:55pm
can't braze aluminium to steel On 26th Oct, 2004 TurboDave16v said:
28th Apr, 2012 at 07:59:17pm
is it not all the same material? Edited by wng691s clubby on 28th Apr, 2012. Done now needs redoing lol |
28th Apr, 2012 at 08:08:05pm
http://jbweld.net/products/jbweld.php
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
29th Apr, 2012 at 07:11:54am
I would try epoxy clue.
If i have more toys than you when i die, I WIN |
432 Posts Member #: 7856 Senior Member Essex |
29th Apr, 2012 at 08:01:38am
I have one here somewhere if you can't fix yours ontime |
29th Apr, 2012 at 08:50:21am
I have one somewhere. But mine has been chemical metalled up on the flange, as it had cracked. It was fine for 3 years like that.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
29th Apr, 2012 at 09:24:25am
i just pressed mine back in with the vice.... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
319 Posts Member #: 1742 Senior Member essex |
29th Apr, 2012 at 09:36:09am
how loose is it? My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
29th Apr, 2012 at 12:07:42pm
id press it back in with some epoxy or a sticky silicone selant. turbo 16v k-series 11.9@118.9 :)
29th Apr, 2012 at 05:49:40pm
Thanks for the advise, it is tight and won't go back in, I think heat and pressure will put it back but I'm not sure I can trust it to hold. I am going to try a local engineering workshop tomorrow, I want to see if they can make an alloy tube and weld it together I can then be assured it won't fail .
1st May, 2012 at 08:20:59pm
http://www.ebay.co.uk/itm/Mini-Turbo-Metro...=item4603606b27 heres one Done now needs redoing lol |
![]() 825 Posts Member #: 2208 Post Whore Essex |
1st May, 2012 at 08:36:26pm
gaffa tape! |
![]() 673 Posts Member #: 1395 Post Whore chepstow |
2nd May, 2012 at 07:50:03am
I have one you can borrow to get you to the riv run/back on the road. Then when you buy another you can send me that one |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
2nd May, 2012 at 10:00:26am
buy one of these....
"Cars are a lifetime of pain" |
2nd May, 2012 at 10:42:04am
That's for the block he's after the bit turbo end Edited by bennyy on 2nd May, 2012. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
2nd May, 2012 at 06:09:23pm
I have several of these if you're still stuck. |
